Ade
HowieD wrote:hello,
are you really usig the original lines ? prolly due a change by now then ? Hell are a good replacement
regards
Howie
ADE wrote:Might be a stupid question.Did you clean the grooves out where the seals go.A little corrosion and they won`t fit in the grooves as they should.Pistons go out but struggle to go back as they are sticking to the seal
Ade
Pigford wrote:johny brando wrote:zorded wrote:Its not the new caliper seals sucking the pistons back in is it?
Banjo bolts bottoming out in the splitter? Mine were, i ditched the splitter and fitted two full length hoses off the MC!
Thanks for your help here. But I don't really understand what your saying about a sucking action ??
The pistons don't actually slide in the seals when being used.
When braking, the pistons stretch the rubber seals as they only move a tiddly bit, then when released, the seals spring back, pulling the piston away from the disc.
johny brando wrote:Pigford wrote:johny brando wrote:zorded wrote:Its not the new caliper seals sucking the pistons back in is it?
Thanks for your explanation ...appreciate that. That is exactly what I stated in my reply to Zorted ....see my reply above dated 16th August.
