I have to change the stem seals on my Z900 A4. Which ones shall I go for
Kawasaki originals or any other recommendations
Valve stem seal
Valve stem seal
Gavin
If it has the original phosphor bronze valve guides they also may need replacing for later cast iron ones as the original guides are/were a well known weakness on the Z1/Z900 range.
Had to replace them all on my A4 during the recent resto. Guide seals used were the Viton ones supplied in the gasket kit supplied by Z-Power.
