Clutch Issues
				Royalratch
Clutch Issues
Hi lads.
On my 'other' bike feel like clutch is slipping (acceleration does not match not revs) after 4000rpm.
Its done 8500K and pretty sure its the original clutch. Shouldn't these last longer? Its an 08 Speed Triple.
I've adjusted the cable so its on maximum slackness at both ends but still slipping - so the clutch is worn?
When I replace it - will it be obvious that the plates are worn - should I measure them.
Doubt it could be anything else...
Thanks!
Thanks!
				Royalratch
Royalratch wrote:Nope.
Fully Synth Castrol Power 1 bike specific oil - as per Triumph's recommend.
Though some people say full synth causes slippage - which seems plain wrong to me.
The fact that the cable is all the way out points at a when clutch...
Isn't "fully synthetic" too "slippy" for a wet clutch??
Jimmock.
I hate people I don't like !
				Royalratch
				Royalratch
So I got the clutch out for inspection.
To be honest I can't see anything wrong. The plates all came apart easily (so no sticking) and the steel plates show no sign of scoring or burning. The basket and ears also appear fine.
The friction plates I don't really know if they're worn or not - perhaps you guys can tell me. The actual friction blocks seem very low but that may be the normal height. Some new clutches are thicker and some are low so can't tell.
Should I just put them back and try a new clutch cable first? Don't really want to change the oil as its not even done 1000 miles.
As I said, the bigger concern is why this has happened at only 8000k.
wn:
wn:Re: Clutch Issues
Royalratch wrote:Hi lads.
Thanks!
you haven't fiddled with the clutch lever or master cylinder recently have you ?
could be a lack of any 'slack' in the hydraulic system causing a slight pressure on the clutch
don't ask me why i'm suggesting this....
				Royalratch
Hi mate.
Cable clutch so no hydraulic issues. Correct free play dialled in.
				Royalratch
Royalratch wrote:Thought swapping the plates about was a no-no?
Save for the first driving plate on some bikes - They are not a matched set, they are mass produced items.
They bed together and 'burn' when they start slipping leaving polished areas.
When you mix them they have to bed-in again. if necessary scuff the faces of the steel driven plates with scotchbrite or wire wool to clean them up.
Users browsing this forum: No registered users and 2 guests
