Carburettor drain off pipes
csnurney
#1 PostAuthor: csnurney » Sun Jan 13, 2008 7:20 pm
Hi,can anyone tell me please how long each length of carb drain off pipe is please.Just came in one length from z-power.Also where does the rubber carb clamp wrap round.is around the groove shape spacer near frame.
Thanks Chris
foreverinthegarage
#2 PostAuthor: foreverinthegarage » Sun Jan 13, 2008 8:37 pm
Hi Chris
yes you are right the rubber fits in the grove on the spacer. as for the pipes if you start with no1 carb and run the pipe down through the rubber guide untill it comes out the bottom of your swing arm then cut it off thats the first one done, now do the same with the rest.
Z1000 The King is Still Alive
Mick
