Rear suspension units
sprint
#1 PostAuthor: sprint » Wed May 27, 2015 10:25 am
Have fitted a pair of Z Power std replacement rear suspension units and boy are they hard! They are crippling my back and I need something with a lot softer springs.
Does anybody know what the spring rate is of the std units are, which I doubt you can get softer springs for?
What are the alternatives as I don't want to spend a fortune as the bike is only used for gentle riding around?
Basic Hagons start at around the £150 mark, £180 if you want top spring covers. Are there and other alternatives with softer springs?
becker
#2 PostAuthor: becker » Wed May 27, 2015 11:56 am
Have some Progressives on my Z1000 - bought them a year or two ago when a bit tight for money as a cheap replacement for some MoT failure ones. Think they where cheaper than the Hagons.
They look good, but are a bit soft for me and I think softer than the std's on my 900.
They might be for sale soon :wink: when I get round to getting some piggy backs repaired or find some bargain Ohlins :shock:
When life hands you lemons, reach for the vodka.
Z1A, Z1000A1, ZRX1100 C4, Suzuki TS125J (1972 basket case), most of a 1975 Garelli Rekord
jphaynes669
#3 PostAuthor: jphaynes669 » Wed May 27, 2015 8:17 pm
Koni dial a rides.....perfect for general riding.
Jeff.H
Gavin
#4 PostAuthor: Gavin » Wed May 27, 2015 8:29 pm
I have Hagons on the 900 and I find them quite hard even on the softest setting
Gavin
sprint
#5 PostAuthor: sprint » Thu May 28, 2015 11:46 am
Gavin wrote:I have Hagons on the 900 and I find them quite hard even on the softest setting
Thanks for the reply.
I was looking at the Hagons, as they are reasonably priced. However, that you find them hard even on the softest setting is a bit of a worry. When I spoke to them they advised that all their units are fitted as std with 110 lb in springs?
Not knowing what the spring rate is on the existing Z Power ones make it difficult to judge? Z Power don't know what the spring rate is of the units they supply, which is a bit disappointing.
sprint
#6 PostAuthor: sprint » Thu May 28, 2015 11:48 am
jphaynes669 wrote:Koni dial a rides.....perfect for general riding.
They are nice, but at over £300 they are bit more that I really want to spend.
Gavin
#7 PostAuthor: Gavin » Thu May 28, 2015 12:05 pm
I was looking at the Hagons, as they are reasonably priced. However, that you find them hard even on the softest setting is a bit of a worry. When I spoke to them the advised that all there units are fitted as std with 110 lb in springs?
I forgot to add that i have not had a bike with twin spring rear shocks for 17 years, then i doubt the springs were that good on my Mk2
Gavin
Compo1955
#8 PostAuthor: Compo1955 » Thu May 28, 2015 4:34 pm
I Had Z Power shocks on mine when I got it and had the same problem, far too hard.
I replaced with Hagons, they transformed the ride, and not too hard.
If it ain`t broke.....don`t fix it
C90
W650
ZRX1200R
Z1A
sprint
#9 PostAuthor: sprint » Thu May 28, 2015 5:12 pm
Which version did you go for and as far as you know were they the std springs supplied?
sprint
#10 PostAuthor: sprint » Thu May 28, 2015 5:14 pm
sprint
#11 PostAuthor: sprint » Thu May 28, 2015 5:15 pm
Mark Tiller
#12 PostAuthor: Mark Tiller » Thu May 28, 2015 5:18 pm
roads are a lot worse than 17 yrs ago
Chris Riv
Replacement shocks
#13 PostAuthor: Chris Riv » Thu May 28, 2015 7:04 pm
I have been down this road. The shocks I had (replacement from Z power) were very hard. This was due to a lot of damping on compression so regardless of spring setting, the damper couldnt compress quickly. I went back to a set of std genuine shocks & they are a great improvement up to about 70mph two up. Above that theyre not up to the job. I have dial a rides on my z1000 & have had them on several Z1's. Deffo recommended. Not experienced hagon twin shocks, but have a hagon mono on my FJ1100, very good shock with a massive operating range (ie solo or two up with luggage).
cheers, Chris.
Compo1955
#14 PostAuthor: Compo1955 » Thu May 28, 2015 7:33 pm
I don`t know what the spring rate is, standard as far as I know. Mine are the 35007 cc1 version. Also I wheigh about 13 stone with my bike kit on. Hope this helps.
C90
W650
ZRX1200R
Z1A
sprint
#15 PostAuthor: sprint » Fri May 29, 2015 7:50 am
Thanks for the replies.
I'm about the same at 13st kitted up so I will give the Hagon's a try. If they are no better then they can always go back.
