Rust in tank
sockpuppet
Rust in tank
#1 PostAuthor: sockpuppet » Sun May 17, 2015 5:08 pm
Last week i cleaned out the rust in my z1100r tank using the
coke/limescale cleaner method , it came out pretty good .
Straight afterwards i flushed it out and put in some parrafin and engine oil
mixed together and swilled it all around the tank assuming this oily mixture
would deter any more rust forming.
As you all will have guessed by my post it didn`t work !
If i clean it out again do i have to fill it with to the top with fuel to stop this
happening again ? .
Or is there a company who can clean it out properly and line it for me ?
Any advice gratefully received !
Thanks Mick
nigel bessant
#2 PostAuthor: nigel bessant » Sun May 17, 2015 6:12 pm
I used this method recently on a triumph tank and I pressure washed it afterwards, blew it dry with compressed air and emptied a can of WD40 into it, swilled it around and for more than a month it has been fine.
Nigel
sockpuppet
#3 PostAuthor: sockpuppet » Mon May 18, 2015 8:47 pm
Thanks Nigel
i`ll give that a try !
Mick
jez1100r
#4 PostAuthor: jez1100r » Sat May 23, 2015 4:17 pm
just had my z1100r tank done but mine had a hole in it this company did a good job
http://mts-motorcycles.co.uk/services/
sockpuppet
#5 PostAuthor: sockpuppet » Sat May 23, 2015 4:29 pm
Thanks i`ll keep them in mind .
Did they do a full tank refurb/spray etc or just inside ?
Mick
guzziman56
#6 PostAuthor: guzziman56 » Sun May 24, 2015 10:41 am
If you google 'real classic petrol tank cleaning and rust removal' you will see an excellent method by Les Howard. I'm about to give it a go.
1981 KZ1100 Shaft+Steib TR500 sidecar (ongoing), 1942 Motoguzzi 600U, 1948 Moto Guzzi GTV, 1952 Moto Guzzi Ercole (in bits), 1953 Nimbus, 1986 Moto Guzzi V65 Lario (in need of TLC), 1988 Moto Guzzi Mk V Le Mans
