UniTrak charging
tlc
International Rep
UniTrak charging
#1 PostAuthor: tlc » Sat May 16, 2015 4:42 pm
This is all new to me but I have a charging problem.
As far as I can tell the Reg Rec is good. I've done the static resistance tests.
It's the output from the stator I think I need help with.
Any pointers chaps?
Asphalt Cowboy
#2 PostAuthor: PAULJAC47 » Sat May 16, 2015 5:09 pm
Hi Chris, should be standard 3 phase genny, with engine running you should get about 50 volts ac across any 2 and all of the three output wires in any combo,you should get about 14.6 volts dc across the battery at about 3k revs,Cheers Paul J
tlc
International Rep
#3 PostAuthor: tlc » Sat May 16, 2015 5:38 pm
Hi Paul.
I will do the check thanks. My god the gen manual is confusing.
I knew someone would know a simple way.
Asphalt Cowboy
