Advice required on how you are meant to hold things steady (locked) so as to successfully torque up the Clutch Hub Nut and Alternator rotor bolt.
I read somewhere that you are meant to select a low gear and then hold down on the rear brake.... well this does not work.
Can anyone advise as getting close to finishing engine rebuild ( almost 2 years
) but cant close her up until these are done.
