Z800 Cafe Chopper Fighter thing...
#271 PostAuthor: Pigford » Sun Mar 15, 2015 12:04 pm
Nice clip - clever camera indeed :wink:
Royalratch
#272 PostAuthor: Royalratch » Mon Apr 27, 2015 1:11 pm
Next question!
If earth points are at touching the frame at certain places - is that bad? The battery box has an earth bar which I use for all the loads other than Starter and Engine but it is mounted to the battery box by metal tabs - will that be a an issue?
#273 PostAuthor: Pigford » Mon Apr 27, 2015 1:27 pm
Royalratch wrote:Next question!
More earth points on frame/engine, the better (within reason) :wink:
Royalratch
#274 PostAuthor: Royalratch » Mon Apr 27, 2015 3:26 pm
Cheers Pigford.
But I'm not using the frame as earth - everything is running back to the battery -ve.
Just making sure I don;t get any shocks touching the frame or cause gas tanks to blow up lol.
#275 PostAuthor: Pigford » Mon Apr 27, 2015 3:57 pm
Still advisable to have a good earth betwix frame & engine.
jimmock
#276 PostAuthor: jimmock » Tue Apr 28, 2015 5:47 pm
Royalratch wrote:Cheers Pigford.
An insulated return system?
Jimmock. :wnkr
I hate people I don't like !
Royalratch
#277 PostAuthor: Royalratch » Wed Apr 29, 2015 11:52 am
Does that mean that at no point does any Earth wiring touch the frame at all?
What I'm trying to understand is if one of the earth points touches the frame anywhere, is that okay?
I guess the engine has a big fat earth cable running to the battery and the engine is itself touching the frame in many areas so it might be a nonsense question...
jimmock
#278 PostAuthor: jimmock » Wed Apr 29, 2015 2:52 pm
Petrol tankers use an insulated return system.
ie, NO earth uses the chassis as a return path to source (battery).
Everything is brought back to battery via insulated wires.
Jimmock. :wnkr
Royalratch
#279 PostAuthor: Royalratch » Wed Apr 29, 2015 3:19 pm
Clear.
But my earth distribution bar is mounted to the battery box via metal studs - so there is a small path - but electricity follows least resistance so the fat earth strap going to battery will probably sort that.
#280 PostAuthor: Pigford » Wed Apr 29, 2015 3:50 pm
All the bike kit ain't designed for an insulated earth, so best make sure frame & engine is sound.
jimmock
#281 PostAuthor: jimmock » Wed Apr 29, 2015 5:29 pm
Why are you not using the frame and engine as a return route?
Jimmock. :wnkr
needaz1100r
#282 PostAuthor: needaz1100r » Fri May 01, 2015 8:43 am
I'm not sure you can avoid it, the body of the starter motor will be the same potential as the battery negative, there's no separate negative terminal on a starter motor, so the motor will have to be earthed, or negative, the motor is bolted to the frame. You may end up with multiple paths, but that doesn't hurt, it's perfectly normal. All you'll en up with is more wire than you need.
No piece of wire will have a lower resistance than the frame.
Mark.
Royalratch
#283 PostAuthor: Royalratch » Sat May 02, 2015 9:05 pm
The engine will have a fat earth strap to the battery Neg terminal.
I may have fluffed my question - clearly its okay for various components and earth [points to touch the frame,
But any +12V lines must be fully insulted from the body then correct?
Otherwise you have -ve and +ve both contacting the body - not good?
#284 PostAuthor: Pigford » Sun May 03, 2015 9:22 am
Royalratch wrote:But any +12V lines must be fully insulted from the body then correct?
100% correct :!:
Crofty
#285 PostAuthor: Crofty » Sun May 03, 2015 11:57 am
Royalratch wrote:any +12V lines must be fully insulted from the body
What do you say to insult it Ratch? :lol: :lol:
