Well done sir
UNLIMITED LTD - The Pigford Project
Blinky Blimey - 3 months since anything was done
Wheeled the bike out into the sunshine after fitting some Hagon shox. The JMC s/arm raises the arse end an inch or two, so could ideally do with some shorter units.
Apart from a tidy-up, all that needs doing is to sort out the wiring and she should be a runner. The MOT is until Aug 2015 so hope to get a few miles in before the end of summer
.... lovin' the retro look of the skinny TT100's
Not to everyones taste, but makes a change for me. After much thought I'm selling my recent aquisition ....
http://www.ebay.co.uk/itm/141596967998? ... 1586.l2649
.... as I'll be sticking with this project & need the cash to progress
						Anuvver month roles by...... and not alot's happened, except I've refitted the LTD tank & sdeat unit, also fitted a standard seat for a change. Surprising how much time it took just swapping fuel tap & getting seat lock to fit nicely. Also stuck some Z1000 plaques on the sidepanels:
Still got the wiring to tackle
						Been a few weeks since any action..... so as I had another day orf I decided to tackle the Air emission passages in the head. After thinking about plugging them with some "metal putty" I thought I'd do it proper-like and tap them out to M10 x 1.5mm and get some suitable grub screws to loctite in place.
Just need to order 4 x grub screws (eBay) and fit them, then it'll be tine to sort the bleedin' wiring out
						- coldsummer
coldsummer wrote:Why did you put the old LTD tank on Mark? Thought they were best consigned to the skip?
Simon, I just like the colour better - as I haven't got the cash to get the A1 stuff repainted
						Much thanx to Coose for GIVING me a NEW tube of Loctite 648 (f.o.c) so I could seal in the M10 x 1.5mm grub screws to block the air emission passages....
... the cam covers just needed a quick brush with the file and fitted lovely - the grub screws were 16mm long - in hindsight 12mm would have been best, but these screwed in and tightened up nicely
Thats the engine stuff complete now... so it's onto the WIRING
						UpDate; Did a bit of wiring - the ignition switch now controls the ...errrm, ignition via a Wired by George relay.
Got some Raask's off Padders (cheers lad) and decided to change the rod rear drum brake for a wire (bowden) type - just like a Kettle GT750
This method not only allows you to adjust the chain tension without re-adjusting the brake, it also let me use my little alloy bracket I got with me old Z1000 - it's an emotional attachment kind-a-thing
Brake switch wire is just a temporary affair, but the little bracket restricting brake pedal movement is there to stay..... I like the basic/functional stuff, as we did back in the day. Just gotta fit t'other side next
						- RALPHARAMA
Pigford wrote:Been a few weeks since any action..... so as I had another day orf I decided to tackle the Air emission passages in the head. After thinking about plugging them with some "metal putty" I thought I'd do it proper-like and tap them out to M10 x 1.5mm and get some suitable grub screws to loctite in place.
I'm surprised you would spend money on grub screws
How you getting on with my old lathe?
Ralph Ferrand
