After it's winter break took the Gpz out in the lovely spring sunshine and after a nice blast it would not fire back up battery had flattened itself. A quick investigation found melted block connector to reg/rec , and only continuity between 2 of the 3 yellow alternator wires, one of the windings had broken.
Had a spare alternator (untested) with continuity between all 3 wires and a B1 reg/rec which I have fitted, block connector and cables replaced, wiring checked ,terminals cleaned.
Now with a multimeter across the battery terminals still only getting battery voltage at 4000rpm
Electrics are not my thing and I would be grateful for a few simple tips ( and I mean simple ! ) to check what I have . The factory manual has tests for the reg/rec but that goes straight over my head .
Any help would be appreciated and any ideas what went wrong and in what order it happened and is this common ?
Richard
