Top carb vent hose
sprint
Top carb vent hose
#1 PostAuthor: sprint » Mon Mar 30, 2015 6:57 pm
Can somebody suggest/recommenced a suitable black tube/hose to use for the top carb vents on a 76 Z900A4? What I/D and O/D is used?
Steve Cooke
#2 PostAuthor: Steve Cooke » Mon Mar 30, 2015 7:39 pm
8mm OD x 5mm ID, 8x6 can be a bit loose but probably varies depending on hose used, fine if using a clip, it's also a bit more of a plastic type rather than soft rubber. Mine are about 400mm long which takes them to about 3/4 along the length of the silencer.
#3 PostAuthor: z1bman » Mon Mar 30, 2015 7:59 pm
sprint
#4 PostAuthor: sprint » Mon Mar 30, 2015 11:06 pm
Thanks for the reply and link
