Got the head back from 'mansfield engines'.
They did all marvel of things
 , heli coiled it , re-seated the valves, did some 'drop test' ( the last tjme I did that it broke some fins off
 ), I was totally glazed over by now and my lack of knowledge had already left the building
I did get that they had welded up the ends (much needed) and due to valves being 'topped'?
and re ground, logging all the shim thicknesses etc was a waste of time?
I think I'll be studying the chrisu's 'shimming sticky' when the time comes and i'll also be a permanent thread starter in 'bike help' section
the ends wanted some serious grinding/attention, fortunately the end caps cover most of it.
a bit more 'sanding' will be required to give it a better shape:|
well the engine is definitely getting a thick coat of silver paint
“It's not me who can't keep a secret. It's the people I tell that can't.â€Â
freddyz1r
PUM 329
