US Spec LTD Indicators
fusionpaul
#16 PostAuthor: fusionpaul » Mon Jan 19, 2015 7:09 am
Well I was told last week mine would not Pass with the front running lights connected, easy fix, but I suppose different MOT testers may interpret the rules differently ??
ted1r
post
#17 PostAuthor: ted1r » Mon Jan 19, 2015 9:56 am
Further quote from UK motorbike test rule section 1-5
Amber lamps located within the indicator lamp must not adversely affect the operation of the indicator i.e. the indicator must go on and off to function not dim and bright.
This is ok with dual filament bulbs. 5/21 watt
Ted
"Work this is why I did it"
"I've had more minutes than I have left"
Z1R D1
Granada
vantastic Transit........
KLE650
Farmer
#18 PostAuthor: Farmer » Wed Jan 21, 2015 7:34 pm
whilst picking up the carbs today I asked about indicators and headlight, headlight is ok with a bit of tape on it, just as well as Z power have not got any, and the indicators are fine too, as the new European H**** monkey bike has a similar set up. :)
1981 KZ1000 K1 LTD
Rob McCool
#19 PostAuthor: Rob McCool » Mon Feb 23, 2015 3:28 pm
I`m having the same problem with the lights on my 1982 KZ1000LTD which I`m trying to get up to scratch to register here-the bike had been damaged in transit to the UK,getting hold of a replacement headlight was difficult as they`re only really available in the states.I did read on the web though that there was a european spec 1981 Z1000LTD. :!:
Richard Q
#20 PostAuthor: Richard Q » Mon Feb 23, 2015 3:39 pm
My old Suzuki GS1100GK had the indicators on all the time. The MOT station called me to say it would fail on these but they could disconnect them and they would pass it.
As I quite liked them, I went to reconnect them when I got home, to find they had just cut the wires :evil:
1976 KZ900
ted1r
post
#21 PostAuthor: ted1r » Mon Feb 23, 2015 3:58 pm
The bike will pass an Mot with them lit orange and on 5 watts only , I have a full uk mot no side light in head light but the indicators are yellow.
Ted
Z1R D1
Granada
KLE650
Bill Newman
#22 PostAuthor: Bill Newman » Mon Feb 23, 2015 11:29 pm
Farmer wrote:whilst picking up the carbs today I asked about indicators and headlight, headlight is ok with a bit of tape on it, just as well as Z power have not got any, and the indicators are fine too, as the new European H**** monkey bike has a similar set up. :)
But you will get an advisory note on the MOT document.
Farmer
#23 PostAuthor: Farmer » Wed Apr 08, 2015 8:41 pm
Well mine failed, got to cut the wire it seems, it was a personal safety measure from the tester, I`ve not got a problem with it as its my personal safety he`s thinking of. :)
1981 KZ1000 K1 LTD
