Checking Valve shims
Farmer wrote:I take it then you can only take 1 shim out at a time and then replace it and then move onto the next, or can I take all the shims out before I replace any ?
One at a time only.
If you allow the cam to run direct on the bucket you risk damaging the cam and buckets as the cam will jam against the raised lip on the bucket.
