Z900 A4 Ignition
Wayne1960
#16 PostAuthor: Wayne1960 » Sun Feb 01, 2015 3:18 am
Ok I'm on it I'll give that a go in the morning. Couple of questions?
What colour should the plug caps be, black or red?
What angle should they be, straight, 90 or cranked?
Where would I get the inline connectors from?
Thanks in advance.
Bike now finished what a joy!
#17 PostAuthor: PAULJAC47 » Sun Feb 01, 2015 10:19 am
http://www.ebay.co.uk/itm/IN-LINE-HT-LE ... 418dcd2e17
Wayne ,above should do trick,by using needle technique you can find which ht lead may be broken,do test from ht cap end with caps removed to see if one of the ht caps may be faulty,most a4s now have black Nkg caps fitted,doesnt really matter what angle they are unless you want it to look original.Easiest way to check secondary resistance is to push your meter probes into the insulation at plu cap end alongside the wire and get reading between the two ht wires.
Wayne1960
#18 PostAuthor: Wayne1960 » Sun Feb 01, 2015 12:03 pm
Paul
Taken coils off the bike and carried out tests as you described. Coiled for 1&4 had good readings but 2&3 nothing. I cut the HT leads back at the coil leaving enough to extend with new and again nothing.
Thanks for all you help guys but I think best to replace both.
So if I want authentic look should I go for black caps and what are the authentic angles, anyone have a picture?
#19 PostAuthor: z1bman » Sun Feb 01, 2015 12:35 pm
Wayne1960
#20 PostAuthor: Wayne1960 » Sun Feb 01, 2015 12:44 pm
Z is the answer that they should be black and cracked or they should be metal
#21 PostAuthor: z1bman » Sun Feb 01, 2015 12:53 pm
this is what is listed in the parts diagram & it is black very close to the ones i have posted you will need 2 of each cap
http://www.ebay.com/itm/KAWASAKI-SPARK- ... 1118890337
http://www.ebay.co.uk/itm/NOS-Kawasaki- ... 0725547833
http://www.ebay.co.uk/itm/NGK-SB05F-Spa ... 3f419bf10c
Steve Cooke
#22 PostAuthor: Steve Cooke » Sun Feb 01, 2015 1:08 pm
If your bike is a US import it would have had black plain plastic as the NOS one shown, NGK type plug caps are similar but have the NGK moulded in them, If your bike is a UK bike it would have had the metal type caps as standard, usually dumped pretty quick and replaced with the red NGK caps.
The angles of the plastic ones are as the first two shown in the previous post.
#23 PostAuthor: z1bman » Sun Feb 01, 2015 1:17 pm
similar? to the original uk spec z900 but they are crap
https://www.z-power.co.uk/merchantmanag ... ts_id=2139
Wayne1960
#24 PostAuthor: Wayne1960 » Sun Feb 01, 2015 1:46 pm
Thanks Z and Steve my bike is pure UK. So I guess I'm going to have to get the metal ones but Z recons there crap.
I'm guessing there all that's available!!
#25 PostAuthor: z1bman » Sun Feb 01, 2015 6:26 pm
Wayne1960
#26 PostAuthor: Wayne1960 » Sun Feb 01, 2015 6:44 pm
Wow I realy want them!! Just can't warrant the money and delivery!
#27 PostAuthor: z1bman » Sun Feb 01, 2015 7:24 pm
Wayne1960 wrote:Wow I really want them!! Just can't warrant the money and delivery!
that works out to about £22.50 each & that is what a zrx 1200 plug cap would cost from a dealer today so it aint that bad if you want originality
Wayne1960
#28 PostAuthor: Wayne1960 » Sun Feb 01, 2015 7:33 pm
Ok seeing how much for 4 delivered.
Steve Cooke
#29 PostAuthor: Steve Cooke » Sun Feb 01, 2015 8:10 pm
Not sure that is the same as the A4 ones, but either way I wouldn't bother because they are shite, unless you really want absolute originality and don't intend using it too much. My A4 is very near everything original but plug caps is definitely not one of them. There is a strong case to say it would look more original with a set of NGK's on it because that's what the majority had on them even back in the day. :lol:
Wayne1960
#30 PostAuthor: Wayne1960 » Sun Feb 01, 2015 8:33 pm
Hi Steve decisions decisions I simply don't know what to do !
Is it possible to put the metal shells over the top of the NGK plugs?
