Front & Rear Brake Master Cylinder strip down
needaz1100r
#16 PostAuthor: needaz1100r » Fri Jan 30, 2015 9:16 pm
zorded wrote:
keep you fingers out of the way!!
Someone very clever (not me) said that you can pump out jammed pistons with a grease gun.
I've got a stuck piston in a GS1000 caliper at the moment, compressed air won't shift it, I'm going to rig up a front master cylinder to and old set of bars, connect with an old hose and pump away.
I'm take some pics.
Mark.
#17 PostAuthor: Al » Fri Jan 30, 2015 9:38 pm
Sounds like a plan Mark but no pictures of you 'pumping away' please!!
needaz1100r
#18 PostAuthor: needaz1100r » Sat Jan 31, 2015 9:16 pm
zorded wrote:Sounds like a plan Mark but no pictures of you 'pumping away' please!!
There are videos around if you look hard enough Al.
Mark.
