Q's Z900 A4
#46 PostAuthor: Pigford » Sun Jan 25, 2015 9:22 am
Getting to the really exciting stages now :twisted:
andyb1962
#47 PostAuthor: andyb1962 » Sun Jan 25, 2015 10:12 am
Excellent job Richard ! Be up and running in time for summer :wink:
Andy :wink:
Richard Q
#48 PostAuthor: Richard Q » Mon Jan 26, 2015 9:48 am
Pigford wrote:Getting to the really exciting stages now :twisted:
I was hoping that Piggy, but have run into a stumbling block with the rear caliper :shock: It needs a full rebuild but I am not 100% sure what it comes from. And the disc doesn't quite match the caliper, or it may be the pads which are wrong :shock:
andyb1962 wrote:Excellent job Richard ! Be up and running in time for summer Wink
Certainly hope so Andy, I'll pop it round if you like.
Richard
1976 KZ900
KeithZ1R
#49 PostAuthor: KeithZ1R » Mon Jan 26, 2015 11:05 am
ttiw
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Richard Q
#50 PostAuthor: Richard Q » Mon Jan 26, 2015 12:48 pm
KeithZ1R wrote:
ttiw
Pics :D
1976 KZ900 A4 fitted with a rear disc brake. Fairly sure it's from a '77/78 Z1000. Can anyone identify it?
I seem to be missing the pad springs and the anti-squeal shims.
The pad sits around 6mm too high. They overhang the disc and will obviously cause problems as the pad wears. The disc is (as close as I can measure) 277mm x 6mm. The pads are pictured with a ruler, and are 53mm high, with the centre of the holes at around 47.5mm.
Any ideas as to why the pads are in the wrong place? disc too small for a Z1000? If so, what size do I need? Wrong pads? Mismatched caliper/disc?
1976 KZ900
andyb1962
#51 PostAuthor: andyb1962 » Mon Jan 26, 2015 2:56 pm
Yes Richard pop round when it's finished I'd like to have a look.
I'm sure I can find some biscuits somewhere :wink:
Andy :wink:
Steve Cooke
#52 PostAuthor: Steve Cooke » Mon Jan 26, 2015 6:50 pm
Z1000 caliper and torque arm, so probably Z1000 swing arm, I've just measured a rear disc I have here and it measures 290mm diameter.
Z1parR
#53 PostAuthor: Z1parR » Mon Jan 26, 2015 8:25 pm
The disc on your wheel is very likely a Z650 disc .
0172 . Geoff Parr
#54 PostAuthor: ADRIAN H » Mon Jan 26, 2015 8:39 pm
Z1parR wrote:The disc on your wheel is very likely a Z650 disc .
+ 1 Disc is the problem.
Z1parR
#55 PostAuthor: Z1parR » Mon Jan 26, 2015 8:49 pm
Just been out and measured a spare 650 disc and a Z1R disc .
You defo have a 650 disc .
0172 . Geoff Parr
Richard Q
#56 PostAuthor: Richard Q » Wed Jan 28, 2015 12:18 am
Oh well, that answers the question - so I need a 290mm disc.
Cheers all - I'll go and have a look. Anyone got one they don't want?
Richard
1976 KZ900
000zeds
#57 PostAuthor: 000zeds » Wed Jan 28, 2015 9:30 am
Zeds-R-Us
Richard Q
#58 PostAuthor: Richard Q » Wed Jan 28, 2015 9:37 am
Cheers twozeds
I emailed them a couple of days ago, and need to phone them about it. It states that it's a 280mm diameter :?? and I need a 290mm.
Richard
1976 KZ900
Steve Cooke
#59 PostAuthor: Steve Cooke » Wed Jan 28, 2015 7:23 pm
Do you have the means to refurbish a disc? the one I have here has surface pitting on it so would need a slight skim but it is the full 8mm thickness so plenty to play with. It's undrilled, if you're interested you can have it for a lot less than that eBay one.
Richard Q
#60 PostAuthor: Richard Q » Fri Jan 30, 2015 9:58 am
Steve Cooke wrote:Do you have the means to refurbish a disc? the one I have here has surface pitting on it so would need a slight skim but it is the full 8mm thickness so plenty to play with. It's undrilled, if you're interested you can have it for a lot less than that eBay one.
Hello Steve
Thanks for the offer, but I am contemplating buying a load of new stuff. As the state of it is quite appalling I might as well do the job once and for all.
Richard
1976 KZ900
Users browsing this forum: Bing [Bot] and 13 guests
