I duly rang my dealer to be told ooooo that's an old one, never done that before and we have not got the special tool, Z power say they sell a lot of rebuild kits, so my question is can it be done without any special tools and how, also is it wise to strip the callipers as well.
Front & Rear Brake Master Cylinder strip down
As I found mostly jellified brake oil in the front when I changed the pipes I thought a strip down of the master cylinders a good idea, consulted my Clymer manual and it says see your distributer/dealer to have it done as it needs special tools.
1981 KZ1000 K1 LTD
Dont even need them just bust off the old master plunger with pliers,its scrap anyway new one is in the kit!Calipers are ok,just pump out the old pistons with compressed air or the master cylinder when its working,just be methodical and clean..
needaz1100r
Farmer wrote:Thanks men, not as hard as I thought then
Make sure you clean out the groove where the piston seal sits, it can get corroded and aluminium expands when it corrodes, if you don't clean it out properly it can be a devil's own job getting the pistons back in and if you do they can drag.
This is in the calipers of course.
Mark.
Mark.
I don`t think your talking about the same master cylinder.z1bman wrote:all you need is cir clip pliers like these
http://www.ebay.co.uk/itm/Long-Nose-50- ... 48363468c5
1981 KZ1000 K1 LTD
Steve Cooke
Agree, newly painted parts attract said pistons as well,i just pack with wood or rags to absorb shock...Valid point
The front brake worked ok, I don`t know how with all the jellified oil, I shone my led head torch into the callipers and it looked fairly clean so I filled it up with some brake cleaner spray, took out the bleed nipple and blew it through, I did this twice per calliper and left it at that,
The rear brake worked but was sticking on, took the calliper off and blew through, the oil was fairly clean, peeled back the dust seal to find some crusty stuff, not rust, I squirted some WD40 and pushed it back in the vice, put new braided hose on and bled it up, works fine now, just waiting for front master repair kit from Z power.
thanks for all your help
1981 KZ1000 K1 LTD
needaz1100r
