Titanium Bolts..... Are they strong enough
Mmmm
I was waiting for the 'who ate all the pie' jokes
After sorting out what's going to Mikey for replating, some of the fabricated suspension mounts meant that the original bolts weren't long enough. I originally started searching for stainless, then came accross Titaniam, which isn't that expensive. Change out of £15 for this lot.
http://www.ebay.co.uk/itm/271718141341? ... EBIDX%3AIT
http://www.ebay.co.uk/itm/271721098983? ... EBIDX%3AIT
All Ti-6Al-4V (Grade 5) Which I believe is up to the job.
Thanks Scott for the advice from your tech dept.
Kev...... I'll keep me eye on it!
I was waiting for the 'who ate all the pie' jokes After sorting out what's going to Mikey for replating, some of the fabricated suspension mounts meant that the original bolts weren't long enough. I originally started searching for stainless, then came accross Titaniam, which isn't that expensive. Change out of £15 for this lot.
nigel bessant
Steve Cooke
Steve Cooke wrote:nigel bessant wrote:1962royp wrote:I find the quickest way to lose the wife is sleep with her sister or her best mate.
Her sisters best mate might be a bloke.
Cracked me up that!
+ 1.... BUT......
If you SLEEP with them, surely thats okay - be worse if you stayed AWAKE
nigel bessant
Steve, Just checked your build out in projects, may I say it is extremely impressive mate, the twin lamps and oil cooler fit really well, can't wait to see it finished, please don't sell it (unless you have to) it would be like losing a limb if it were mine.
AKA John Roscoe. PUM #028
1975 Z1B, 2013 Z800
1975 Z1B, 2013 Z800
ROZZER wrote:Steve, Just checked your build out in projects, may I say it is extremely impressive mate, the twin lamps and oil cooler fit really well, can't wait to see it finished, please don't sell it (unless you have to) it would be like losing a limb if it were mine.
It's okay - hes a bit like a starfish
