KZ1000 Compression PSI
I`ve checked the compression and they are all just on or just over 140 psi, so I`m assuming there ok. could someone tell me what it should be please ?.
zed1015 wrote:You are good with 140psi.
More importantly is that the readings have no more than around a 15psi difference between the highest and the lowest as this could indicate abnormal wear or issues with valve seating etc.
They were all between 140 and 145 psi, so should be ok then, thanks for all the replies
