Starter motor
jez1100r
Starter motor
#1 PostAuthor: jez1100r » Sat Jan 10, 2015 5:17 pm
Does any body know which starter motor will fit a z1100r lots on eBay for Zs /GPZs or does anybody have
#2 PostAuthor: zed1015 » Sat Jan 10, 2015 5:23 pm
All the 900 to 1100 air cooled zed starters will fit.
The later NON kickstart 1000 'J' to GPZ1100 are the starters you want as these are more powerful with four brushes as opposed to only two on the earlier 900/1000 kick start equipped engines.
garyd
#3 PostAuthor: garyd » Sat Jan 10, 2015 8:39 pm
You might want to think about one of the CB900 starter motors. They also had uprated motors compared to the 900.
be careful though as there are 2 types.
If I remember I'll have a look at the one I have for my 1170...it has some markings on the caseing.
Aztec Warrior
Starter Motor
#4 PostAuthor: Aztec Warrior » Sun Jan 11, 2015 7:57 pm
Hi,
I was searching for an answer and your recent post may answer my queries.
My 1979 ST1000 has a four brush starter fitted. Maybe this was the year they changed over to the four brush motor!
I was given some spares with the bike including SMBK146, which, apparently, is the 2 brush repair kit. This is no good for my starter. Which part no. or model should I be looking for?
No joy in my searches as yet.
#5 PostAuthor: Al » Sun Jan 11, 2015 8:39 pm
PostPosted: Sun Jan 11, 2015 8:57 pm Post subject: Starter Motor
Hi,
I just replaced my brush base plate with this.
http://www.electrexworld.co.uk/acatalog/SMBK25.html
Perfect fit and very reasonably priced considering you get everything in the picture not just some brushes.
Theres' a wee thumbnail below the main picture which gives dimensions of the brushes too for you to check!
Excellent quality too by the looks of it.
Aztec Warrior
Starter Motor
#6 PostAuthor: Aztec Warrior » Sun Jan 11, 2015 9:06 pm
Nice one Zorded.
That looks like the one indeed. And as you say, a good price too for the whole kit, and looks like no soldering or messing about either. Will get this ordered. I note they list SMBK146 too which has it for the year range of the ST. Must be an anomaly with this four brush motor fitted.
I remember using Electrex many moons r the usual Suzuki GS Regulator/Rectifier replacements. Good people. Never thought to go there. Certainly better than £27 for a pair of brushes?
big green bus
#7 PostAuthor: big green bus » Mon Jan 12, 2015 8:24 am
1980's H**** CB900 fit and work too
jez1100r
starter motor
#8 PostAuthor: jez1100r » Mon Jan 12, 2015 11:48 am
hi is the one looks the same in the picture
http://www.ebay.co.uk/itm/111570507709? ... EBIDX%3AIT
Aztec Warrior
Starter Motor
#9 PostAuthor: Aztec Warrior » Mon Jan 12, 2015 7:04 pm
Cheers All,
Thanks for the tips. Another issue swiftly dealt with again.
Aztec Warrior
Post script.
#10 PostAuthor: Aztec Warrior » Mon Jan 26, 2015 9:35 pm
Electrex bits fitted perfect on my four brush ST starter and seem to work a treat. Real test soon when the carbs/tank go back on.
