GB's Modded Z900 now on a runaway budget!
jimmock
#196 PostAuthor: jimmock » Thu Jan 08, 2015 10:51 pm
GB,
I'm impressed.
BUT..........
Get the bolts out of the head for the exhaust flanges and get STUDS in!!!!!
With a stud you split the load on the threads!!!!
YOU SHOULD KNOW THIS!!!! :wnkr
I don't know where that wee emoticon came from???? HONEST!!!
Jimmock. :wnkr
I hate people I don't like !
#197 PostAuthor: Pigford » Fri Jan 09, 2015 7:27 am
jimmock wrote:Get the bolts out of the head for the exhaust flanges and get STUDS in!!!!!
That was a design error for the old Suzooks IMHO :|
#198 PostAuthor: Ginger Bear » Fri Jan 09, 2015 7:45 am
Jimbo,
I didn't know you cared. :9
Pipe is only 'test fitted'. That head isn't staying on the bike, nor the 6mm bolts.
I have this lot on my watch list, probably cause you a little 'stir'.
http://www.ebay.co.uk/itm/Kawasaki-Z900 ... 19f2f1a47f
Just hoping I might pick up a set at Shepton or another show before coughing up £30+ (Don't forget this started as a budget project). :wink:
As for your Signature emoticon.................... :fou :hon :wink:
# 104
brian 450
#199 PostAuthor: brian 450 » Fri Jan 09, 2015 9:25 pm
Looking good mate :up
coldsummer
#200 PostAuthor: coldsummer » Sun Jan 11, 2015 1:15 am
mick znone
#201 PostAuthor: mick znone » Sun Jan 11, 2015 9:04 am
coldsummer wrote:Image
did they not have colour film when you werea kid coldsummer :shock:
#202 PostAuthor: ZedHead » Sun Jan 11, 2015 9:26 am
Another great project
#203 PostAuthor: Pigford » Sun Jan 11, 2015 10:15 am
:lol: My grandkids actually BELIEVE I lived in a Black & White world as a nipper - thanx to my daft son :roll:
Steve - hows the riding position with the drops :?: Can you actually get yer legs up :shock:
#204 PostAuthor: Ginger Bear » Sun Jan 11, 2015 7:15 pm
Spent a bit of time in the Garage this weekend.
Firstly made up a bracket to hold the lower side panel lug. (You won't believe how much deliberation went into how/where to put such a small part. Still not 100% happy, as you'll see some of it under the panel, but once it's satin black I'm sure it won't stick out too much. :roll: )
Next up was to start on cutting/shaping some 25mm tube for bracing. Not sure I'll go mad with it, but started with a couple of braces on the top tubes.
Then added some behind the motor with a bit of triangulation Kosman style. :D
I had considered fitting another horizontal tube at the front of the motor with a diagonal to make a 'Z' brace, but the Kosman drawings only show one horizontal front brace, so I may leave it at that........ For now. :fou
I plan to source some steel plate to 'gusset' the tubes behind the steering head, again, taking my inspiration from Kosman. :sou
# 104
#205 PostAuthor: Ginger Bear » Sun Jan 11, 2015 7:18 pm
Must add, I searched this forum earlier for 'Bracing' & found this thread very useful.
http://www.z1ownersclub.co.uk/forum/vie ... ht=bracing
# 104
#206 PostAuthor: Ginger Bear » Sat Jan 24, 2015 4:42 pm
Been busy again. :D
Pulled the whole thing apart, cleaned the frame & tacked in my bracing, ready to be welded in by someone that can do a far better job than me. :roll:
Cut off the steering lock tab.
And the shock mounts. :shock: This one is drilled ready to be tapped for the exhaust hanger.
Also removed the rear of the lower LH footrest boss, as this will possibly foul the rivets on the chain. :shock:
Hopefully I'll be able to drop it off on Monday to have the welding finished, then it's off to be powdercoated. :lon :lon
First bit of titanium also arrived today. :drool :drool Gonna have to be careful that this doesn't develop into a habit. :ek :ek
# 104
Padders
#207 PostAuthor: Padders » Sat Jan 24, 2015 5:45 pm
Nice work Steve
PUM 13
Is Vic There
#208 PostAuthor: Is Vic There » Sat Jan 24, 2015 9:32 pm
Looking good.
Why are you using titanium nuts and bolts, I understand that they are far lighter but is it worth the expense? Only asking because people have suggested I use them on the Magnum and I can't see the point, if I had a modern race bike and I was a good rider then yes anything to save weight, but I haven't and I'm not, be cheaper just to go on a diet :D
#209 PostAuthor: Ginger Bear » Sun Jan 25, 2015 3:59 pm
I bought the titanium bolts to fit the suspension rocker. I didn't have anything that was the right length to fit my fabricated suspension mounts. Cost less than £15 delivered so a relatively quick, cheap & 'blingy' solution. :D
# 104
#210 PostAuthor: Ginger Bear » Sun Jan 25, 2015 6:42 pm
Just had an update from Buzzard who's doing my head work.
Head machined to take APE cam chain idler adaptor. :D :D
# 104
Users browsing this forum: No registered users and 5 guests
