Rear wheel spacers [again]
walshyco
#1 PostAuthor: walshyco » Tue Dec 02, 2014 3:20 pm
I am fitting genuine Kawasaki alloy wheels to a Z1000 A1, and still having problems. I got an alloy wheel sprocket carrier from Piggy, now when I tighten it all up the wheel locks solid. The caliper is free so I think that side is OK the centre spacer is the one that came with the wheel so that one is OK the ones I have used on the sprocket side are from the wire wheels. According to Partszilla they are the same as alloy ones, but still no joy. Can anyone advise what spacers I need or does anyone have any they want to sell, I don't mind trying to buy some from Ebay but I just don't know what sizes. Hope someone can help. Sean. :roll:
KeithZ1R
#2 PostAuthor: KeithZ1R » Tue Dec 02, 2014 3:58 pm
Difficult diagnosing from a distance but are you getting any clues when you fit the wheel ? are you having to " spring" the swing arm to get everything in or is the arm "pulling in " when you tighten stuff ? have you changed the bearings and are they sat fully home in the carrier does it spin freely until to clamp it up is the spacer between the sprocket carrier and the wheel present ..pictures may help
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
walshyco
#3 PostAuthor: walshyco » Tue Dec 02, 2014 4:19 pm
Hi Keith, Thanks for your reply,I have too big a gap on the sprocket side, and when I tighten the nut it runs out of thread before it fully tightens so only partially locks. I am pretty sure it is a spacer issue [obviously] and It must be the sprocket side two because they are off wire wheels but I have tried packing with washers, no joy, ideally I could do with trying a couple from alloys and then get some made up or try and get some from Ebay. I suppose just knowing the size for alloy wheel spacers would be a big help. Thanks. Sean.
scott
Junior Section leader
#4 PostAuthor: scott » Tue Dec 02, 2014 4:20 pm
Walshyco ......i know this may sound a bit daft but it happened to me and i had similar symptoms. On my zx7r i put the rubber cush drive in the wrong way around and it had the same effect as yours.....would not turn over.
walshyco
#5 PostAuthor: walshyco » Tue Dec 02, 2014 4:41 pm
Thanks, Scott I will double check that, but I think it will only really fit one way round. Cheers mate. Sean.
#6 PostAuthor: z1bman » Tue Dec 02, 2014 4:50 pm
what bike are the wheels from? z1000mk2 if so according to the diagrams i use the sprocket inner & outer spacers are different
walshyco
#7 PostAuthor: walshyco » Tue Dec 02, 2014 5:06 pm
Correct, the wheels are from a mark two sounds like I have got the wrong spacers then. do you know the sizes of the correct ones. Sean.
#8 PostAuthor: z1bman » Tue Dec 02, 2014 5:09 pm
no sorry it only gives the part no & they are no longer available
jimmock
#9 PostAuthor: jimmock » Tue Dec 02, 2014 5:30 pm
Buy a lathe !!!
Jimmock. :wnkr
I hate people I don't like !
#10 PostAuthor: z1bman » Tue Dec 02, 2014 5:38 pm
jimmock wrote:Buy a lathe !!!
:lol: :lol:
walshyco
#11 PostAuthor: walshyco » Tue Dec 02, 2014 6:21 pm
:lol: :lol:
The only way I could fit a lathe in would be to get rid of the bike. But thanks for the advice :wink:
#12 PostAuthor: z1bman » Tue Dec 02, 2014 6:51 pm
the spacer between the two wheel bearings are different part nos
z1000a1 uses 42010-030
z1000mk2 uses 42010-039
rear sprocket hub inner spacer
z1000a1 uses 42036-024
z1000mk2 uses 42036-033
#13 PostAuthor: Pigford » Tue Dec 02, 2014 6:59 pm
Sean, I'll measure the one off me LTD tomorrow at work :wink:
walshyco
#14 PostAuthor: walshyco » Tue Dec 02, 2014 7:01 pm
Thanks for that. I think I will just look out for a complete Ltd rear wheel and get everything. Safest way other than buying a lathe.
walshyco
#15 PostAuthor: walshyco » Tue Dec 02, 2014 7:02 pm
Thanks Piggy. I owe you one again. :wink:
