Calipers
walshyco
Calipers
#1 PostAuthor: walshyco » Sat Nov 15, 2014 10:06 pm
Another weird question, will Z650 calipers fit on to Z1000 fork legs. There are a couple on Ebay but the seller says they will not fit a Z1000 because the bleed nipple will be in the wrong place :?? they also said they could not be mounted at the front of the forks. can anyone shed any light on this please. Thanks. Sean.
z650freak
#2 PostAuthor: z650freak » Sat Nov 15, 2014 10:09 pm
Think from memory they fit but one will be a bugger to bleed because nipple is on the inside (?)
Z1parR
#3 PostAuthor: Z1parR » Sun Nov 16, 2014 12:19 pm
Yes z650 and z1000 calipers are the same , i have both .
I'm sure i've a spare set of 1000 ones here .
I'll have a look in a bit .
0172 . Geoff Parr
z650freak
#4 PostAuthor: z650freak » Sun Nov 16, 2014 1:42 pm
Z1parR wrote:Yes z650 and z1000 calipers are the same , i have both .
Depends on if mounted front or rear :?: :?:
Z1parR
#5 PostAuthor: Z1parR » Sun Nov 16, 2014 2:17 pm
Sorry Paul you're very right .
I should take a bit more care reading before i type :oops:
0172 . Geoff Parr
