Crank case bolt 116mm
jphaynes669
#16 PostAuthor: jphaynes669 » Thu Nov 13, 2014 7:27 am
If your struggling, make one!. You will need m6 stainless t12 threaded bar, a washer, flush fit nut and a blob of weld.116mm cut from the underside of the nut, clean up the thread where cut..job done! :D
Jeff.H
jphaynes669
#17 PostAuthor: jphaynes669 » Thu Nov 13, 2014 7:29 am
Oh,,, and dont forget to use a torque wrench :wink:
Jeff.H
Crofty
#18 PostAuthor: Crofty » Thu Nov 13, 2014 8:56 am
In post, check pm
freddyz1r
#19 PostAuthor: freddyz1r » Thu Nov 13, 2014 9:43 am
All sorted again richard :lol:
well you know where I am if you get stuck :wink:
cheers freddy :D
“It's not me who can't keep a secret. It's the people I tell that can't.â€￾
freddyz1r
PUM 329
Richard Q
#20 PostAuthor: Richard Q » Thu Nov 13, 2014 9:49 am
jphaynes669 wrote:If your struggling, make one!. You will need m6 stainless t12 threaded bar, a washer, flush fit nut and a blob of weld.116mm cut from the underside of the nut, clean up the thread where cut..job done! :D
Cheers JP - but I have been advised not to use stainless as it's not as strong as the originals, and shouldn't be used on crank case halves.
I had thought of buying a pack of these, then using a 4mm washer, or a 2mm washer and and lopping 2mm of the end (would have to check you didn't run out of thread if you start chopping a bolt though), or whatever was needed, but it would be nice to get a proper one if possible. :)
http://www.ebay.co.uk/itm/M6-X-120mm-Hi ... 259455d9b4
Richard
1976 KZ900
Richard Q
#21 PostAuthor: Richard Q » Thu Nov 13, 2014 9:56 am
Crofty wrote:In post, check pm
Cheers Crofty, PM sorted. :)
freddyz1r wrote:All sorted again richard :lol:
cheers freddy :D
Thanks mate, can't wait to get it all back together now.
Richard
1976 KZ900
jphaynes669
#22 PostAuthor: jphaynes669 » Fri Nov 14, 2014 12:05 am
Dont worry richard, the m6 in t12 stainless is more than strong enough, especially at the torque in crank cases etc. Ive used this material in much tougher enviroments than a bike engine. Dont be concerned in the future, but it looks like the members of this club are your saviours. ....
Richard
:wink: :wink: :wink: :wink: :wink:
Jeff.H
