530 Coversion
530 Coversion
#1 PostAuthor: PAULJAC47 » Sat Nov 08, 2014 8:12 pm
Guyz think its common knowledge i have Piggys old Thou now,looking at the bike its got a 630 chain with offset front sprocket to just clear the 180 back tyre ,would a 530 chain give me a bit more clearance on the tyre or would i need still to space out the front and rear sprockets ,found some info that says 530 is same width as 630?
snotie1965
#2 PostAuthor: snotie1965 » Sat Nov 08, 2014 8:36 pm
A 530 chain id deffo smaller ,so you would end up with more clearance . i could measure tomorrow if you need to know exactly ?
Z1parR
#3 PostAuthor: Z1parR » Sat Nov 08, 2014 8:40 pm
I didn't tell anyone Paul :D
And yes they're the same width .
0172 . Geoff Parr
#4 PostAuthor: PAULJAC47 » Sat Nov 08, 2014 8:45 pm
Mmm i thought they may be same width,could you check Snotie and let us know for def please?
Z1parR
#5 PostAuthor: Z1parR » Sat Nov 08, 2014 8:50 pm
Honestly not trying to be a smart arse or piss on anyones chips .
My Z1R has a 530 kit on and my Z1B has a 630 kit on it .
The difference in the widths is point knob all of a mm .
0.2 to be exact .
0172 . Geoff Parr
#6 PostAuthor: ADRIAN H » Sat Nov 08, 2014 8:52 pm
Z1parR wrote:Honestly not trying to be a smart arse or piss on anyones chips .
0.2 to be exact .
Interesting, will check my two bikes tomorrow. :roll:
#7 PostAuthor: PAULJAC47 » Sat Nov 08, 2014 9:03 pm
What is the difference between 530 and 630 chain? | Print |
We get this one a lot. The size convention for chain is set in a system of 1/8ths. The first number indicates the pitch of the chain (the distance between the centerline of the pins, link to link) a "5" indicates a 5/8ths of an inch pitch, where a "6" indicates a 6/8ths of an inch pitch (3/4"). The second two numbers indicate the width of the rollers (Between the inside edges of the INSIDE side plates of the chain) a "30" in this case, indicates a 3/8" roller width.
530630chain
Generally, if you compare a 530 chain to an equivalent rated 630 chain, you will find that the heavier pins and rollers afforded by the longer pitch will result in a stronger chain construction, and higher tensile strength. In a fixed length of chain, the 630 chain will have fewer pitches, many times resulting in less "set" or "stretch" as the chain wears. The sprockets for a 630 pitch have a matching 3/4" pitch, making the teeth larger, deeper, and stronger at the base of the tooth.
Contrary to popular belief, 530 and 630 chains are the same overall width. A 530 or 630 O-Ring chain will measure approximately 1.070" across the rivets outside to outside. (The master link will be wider by approximately .065")
The GUYZ
Looks like you are right Geoff!!!!
#8 PostAuthor: ZedHead » Sat Nov 08, 2014 9:07 pm
No, the width is the same. It is the pitch that is smaller.
Z1parR
#9 PostAuthor: Z1parR » Sat Nov 08, 2014 9:09 pm
For once . :hoo
It had to happen .
0172 . Geoff Parr
#10 PostAuthor: Ginger Bear » Sat Nov 08, 2014 9:19 pm
Sorry Geoff. 530 is a lot narrower & will leave MrJ's tyre intact.
I'll take some pics tomorrow, with the vernier if nobody proves it first, :wink:
# 104
Z1parR
#11 PostAuthor: Z1parR » Sat Nov 08, 2014 9:23 pm
No i'm not biting and going out in the cold :lol:
Perfectly happy and smug sat here drinking vodka and having a smoke :wink:
0172 . Geoff Parr
#12 PostAuthor: Ginger Bear » Sat Nov 08, 2014 9:27 pm
I'm not going out in the cold either, got me 'Jim jams' on ready for bed. :roll:
# 104
Z1parR
#13 PostAuthor: Z1parR » Sat Nov 08, 2014 9:30 pm
Oh dear , my life's not exactly rock and roll but cocoa and jim jams at 9:30 on a saturday night :shock:
0172 . Geoff Parr
#14 PostAuthor: PAULJAC47 » Sat Nov 08, 2014 9:34 pm
I am numbing having to watch x factor with a rather nice bottle of Vino!!!
Z1parR
#15 PostAuthor: Z1parR » Sat Nov 08, 2014 9:39 pm
Sorry Paul but i'd need a bottle of Glenfiddich to watch that :wink:
0172 . Geoff Parr
