rotor with keyway
rotor with keyway
hi guys
Has anybody got a rotor with a keyway cut in it they want to sell and can anybody tell me why some have a keyway and some dont
cheers baz
cheers baz
as far as i am aware they all have a woodruff key ? are you sure it hasn't sheared ?
http://www.ebay.co.uk/itm/Kawasaki-Z100 ... 3a9aa43ef1
Just found this...... which confirms what Rob has just said.
Later;
http://www.cmsnl.com/kawasaki-1978-kz10 ... ml#results
Earlier;
Later;
Earlier;
these are the best locking washers on the market
http://www.ebay.co.uk/itm/NORD-LOCK-WED ... 2a46fe79b6
https://www.youtube.com/watch?v=cDlmbMV9ICU#t=416
z1bman wrote:these are the best locking washers on the market
those are really good had loads at one time, but £2.20 that's taking the Pish thieving Feckers.
kev edwards wrote:z1bman wrote:these are the best locking washers on the market
pack of ten
http://uk.rs-online.com/web/p/locking-a ... s/0456636/
is there a key way in the crank ?[/quote]
ya, agood clean cut one with no damage, the rotor is very scored though, looks like it was just bolted on as tight as poss and the bolt lock tighted.
dont fancy putting it back on like that again though
does the keyway run the full lenghth of the taper or start halfway down ?
