GB's Modded Z900 now on a runaway budget!
- mick znone
- coldsummer
mick z1a wrote:coldsummer wrote:I've never liked bread and butter pudding. Too many currants or sultanas whatever they are.
fruit coldsummer, its called fruit
Thanks Mick, horrible little things. I reckon bread pudding would be nice with just the bread.
Sorry Steve, but you kinda started it
Ginger Bear wrote:Supplier is Alex (Torques) an Ebay seller, whose service is just amazing.
Can also recommend Torques, quality items at a reasonable price
http://stores.ebay.co.uk/torquesuk/
Those twin spots are just begging for the oil cooler underneath them
Wots up DOHC
Mmmmm, the twin spots are under review, it'll still be twins, but I need to fit my dished Cibies in them. The Triumph cases ain't big enough & just look too 'Triumph'
They also need to be mounted fairly low when fixed to the frame, so the bars will clear them. The other option is to hang them off of the forks, but having all that lot swinging about with the steering ain't exactly appealing.
- wheelysteve
- wheelysteve
Ginger Bear wrote:Dropped off all the bodywork & wheels with Hutchy today, which was all going well until he stood on me dogs tail, which ended with the dog having a chomp at Hutchy's leg.![]()
Sadly for me, I think the price may now have gone up.
Hope i've softened the blow slightly for you today Steve
0172 . Geoff Parr
As far as cleaning fuel tanks goes, I tried a couple of things, first I tried electrolysis or whatever it's called, bit of washing soda and a battery charger which did give pretty good results but you always think you can do a bit better so had a look on the net and discovered......Spirit of Salts, it's a drain cleaner that mainly comprises of hydrochloric acid (nasty).
The result? Clean as a whistle, I'd recommend it to anyone but wear gloves etc and use baking soda to neutralise the acid and make sure you put some oil in the tank straight away cos it'll start going rusty again within the hour.
