GPz900A1 installing carbs
RBY
#1 PostAuthor: RBY » Wed Oct 29, 2014 8:42 am
Finally got all hydraulics working on the GPz900 and managed to get carbs out to clean jets and bowls but darned if I can get the pesky blighters back in between engine manifolds and air box. I seem to recall a similar posting with tips on solving this but can't find it now that I need it!!
Is Vic There
#2 PostAuthor: Is Vic There » Wed Oct 29, 2014 10:10 am
Haha the worst job on a GPz900R :D
Make sure the the rubbers are soft and remember to attach the throttle cable!
'roll' the rubbers back on themselves and use tie wraps to hold them in place, then slide the carbs in and snip the wraps, remember to also fit the large metal springs before you do this.
For further information and possibly pictures join the GPz900R forum, good set of lads that will help and advise.
weaver
#3 PostAuthor: weaver » Wed Oct 29, 2014 10:37 am
my solution is fit a jet kit with filters,more power and easy maintenance going forward
chrispyduck
#4 PostAuthor: chrispyduck » Wed Oct 29, 2014 11:31 am
Yes a very tight job on a GPZ 900 especially as the rubber is likely to have hardened over the years. :shock:
If rubbers are too hard to manipulate into position try using a hair drier to warm them.........they are much easier to move around. I ended up buying new intake rubbers which are softer and therefore easy to get in position :wink:
Fat girls are like M****s, they are fun to ride, you just don`t want your mates to see you.
RBY
#5 PostAuthor: RBY » Wed Oct 29, 2014 10:43 pm
Job done! But geezzz what a mission. Rolling back the air box rubbers worked a treat - it was trying to get those spring rings back in place that took the time - combination of tired fingers, thin piece of wood with contour filed in the end and gentle persuasion with a screw driver. Now that I've done it, there is probably a cunning trick to this as well.
