Boyer problems
Boyer problems
Has anyone had problems with a boyers electronic ignition black box going kaput??? Are they possible to test?? Thanks
KWACKERZ1 wrote:HI I might have one to sell if you need to replace it, I have a few so let me have the model number as I am unsure if mine are 650 or 100.
You could always try it first to prove yours.
Phil
Thanks for the offer but the wiring loom on a bitsa I just bought has a Boyer black box attached still....happy days
Yes, fit a Dyna-S ignition system, loads better.
I've wired bikes for over 25 years and have seen plenty of Boyer black boxes f#ck up. The thin tracks can easily burn out. I used to solder new tracks in, very difficult but possible to fix.
Personally I would jumk it and go Dyna!
Will
Will
Taffus wrote:Hi Paul
I must admit I'm not a fan of the boyer, far to complimented for what its trying to achieve, you only have to look at the relative simplicity of the dyna s.
I personally prefer the newtronics system but even that is overkill when the dyna S does it so well..........
I hear what you are saying but not my bike and we are working to a budget of......not a lot. At least it's running and we are back to where we started just need to track down this problem of running on three......
