Sorry Karen,
I have taken the family to blackpool for the weekend before the half term madness - last weekend of the month are nearly always busy for me personally
Midz Meet Oct
Midz Meet Oct
A word of thanks and appreciation to Karen and Steve for organising the Midz meets.
I hope everything get's back to normal for the first Midz meet of 2015.
Best wishes guys,
luv from Jay & Debbie.
~~~~~~~x~~~~~~~
Best wishes guys,
~~~~~~~x~~~~~~~
Non standard Z900 - purchased from HIGGSPEED - http://www.higgspeed.com/ -
http://www.z1ownersclub.co.uk/forum/vie ... 6a7d5e816c
- paul doran
It was a good run out - took the scenic route there & back through Newbold Verdon & Market Bosworth.
Keith - Yes it was the look I was after- I got the bracket you supplied powder coated and it looks brand new. I spent quite a long time choosing the right shaped lights (Similar to original oblongs but smaller)
Although the bracket 'fits' - the rear indicator stems interfere with the Z1R tailpiece so I had to use slightly longer bolts (Only about 5mm) so the rear light sits very slightly further back - existing wiring accommodated the move & I don't think it shows.
The front ones fitted easier but I had to cannibalise some old indicators that over the years I had smashed in various escapades - but I needed the right shaped bits that fit in the lug to attach the stem.
Anyhow after a day or two of head scratching it all went together ok - and I can revert to standard if I want!
010
