Z1000 R2 cylinder head
Stugill
#1 PostAuthor: Stugill » Fri Oct 24, 2014 8:54 am
I am looking for a decent head to get refurbished for my 1984 Eddie Lawson Replica. I will then put it on once done.
They are hard to come by as the Elr's are a bit scarce but apparently a head from a z1000J 81 onwards will fit. I could stand corrected though.
Stu
freddyz1r
#2 PostAuthor: freddyz1r » Fri Oct 24, 2014 10:00 am
Contact jack, 'londons calling' , he may be able to help :?? :?:
cheers freddy :D
“It's not me who can't keep a secret. It's the people I tell that can't.â€￾
freddyz1r
PUM 329
london calling
#3 PostAuthor: london calling » Fri Oct 24, 2014 12:48 pm
Hi Stu,the 1000J head is the same as the R2 but the R2 has different cams with more lift.
As long as you've got the cams then happy days :D
Basically any U.K. J type head will do,suzh as J1,J2/J3,the K1/K2 LTD and the Z1100 Shaft.
You can also use a GPz1100 B1/B2 but the B1 head will need the fuel injection inlets blanking off.
The GPz1100B2 is the same head as the Z1000R2.
The American heads off the KZ models have emission bollox in the cam cover but this can be blanked off.
Jack
freddyz1r
#4 PostAuthor: freddyz1r » Fri Oct 24, 2014 1:34 pm
Ahhhhh :9 I thought you might know jack :wink:
cheers freddy :D
freddyz1r
PUM 329
london calling
#5 PostAuthor: london calling » Fri Oct 24, 2014 7:42 pm
Jack
Stugill
#6 PostAuthor: Stugill » Sat Oct 25, 2014 3:27 pm
Cheers gents.
The list will enable me to look at a lot more models on the bay, or on other sites in general. The ones I have seen so far look a bit on the rough side to say the least.
