Does anyone know anyone that makes/supplies original style 4 into 1 header/collector for Z1R-1? I can get the silencer from PMC but they do not appear to do the rest.
Ted/Keith?
Z1R-1 Header/Colector
- bulldogbobby
freddyz1r wrote:Nobody makes one to my limited knowledge.
cheers freddy
I don't know of anybody either unfortunately - I'm looking at getting my originals chromed. At the moment, i can get the middle downpipes done with no problem but can't find anyone to do the two outside and collector (they won't fit into the tank)? Any ideas or suggestions would be welcome!
Failing that, I'm back to polishing.......................
bulldogbobby wrote:freddyz1r wrote:Nobody makes one to my limited knowledge.
cheers freddy
RB got 1 done for keith a few years back, maybe ask RB who did it.(nottingham platers@ basford crossings?).
the collector box needs finishing in black
cheers freddy
“It's not me who can't keep a secret. It's the people I tell that can't.â€Â
freddyz1r
PUM 329
freddyz1r
PUM 329
I have spent many a fruitless hour searching for this unicorn, to no avail.
I ended up getting bespoke Stainless replicas made for the D1 and D2 I have at no mean cost only for a flurry of decent sets to come up on Ebay shortly after
...... I did consider cutting the outer pipes free from the collector to have them chromed and having a sleeve arrangement like the two inner pipes to get around that issue however it never transpired. With a lot of patience you can pick up reasonable systems on ebay from time to time but they seem to command big bucks for obvious reasons. I have a 4 into 1 in the loft that is pretty much near as dammit except the collector box I can post pictures it could even be used as a pattern if necessary
...... I did consider cutting the outer pipes free from the collector to have them chromed and having a sleeve arrangement like the two inner pipes to get around that issue however it never transpired. With a lot of patience you can pick up reasonable systems on ebay from time to time but they seem to command big bucks for obvious reasons. I have a 4 into 1 in the loft that is pretty much near as dammit except the collector box I can post pictures it could even be used as a pattern if necessaryKeith
mistaken.
Phil Churchett winner 2013
mistaken.
