Z1000J Front Mudguard
needaz1100r
#1 PostAuthor: needaz1100r » Wed Oct 15, 2014 1:32 pm
Aesthetic condition not important, but would like a straight one.
I am going to destroy it, to start with, so I can make a Z1100R style stay to fit, so the cheaper the better.
Mark.
Re: Z1000J Front Mudguard
#2 PostAuthor: ADRIAN H » Wed Oct 15, 2014 4:27 pm
needaz1100r wrote:I am going to destroy it. Thanks
:shock:
needaz1100r
#3 PostAuthor: needaz1100r » Wed Oct 15, 2014 5:15 pm
It seems harsh for a poor defenceless mudguard, but once I've ground out the rivets so I can use the profile of the stay to make a Z1100R shaped one and rivet that back in it will be restored to be live once more as a more valuable part.
It could all go horribly wrong!!
Mark.
#4 PostAuthor: Al » Wed Oct 15, 2014 6:29 pm
I have a J style bracket on its own, (the one with the holes in it), no blade.
Not much use really but there it is.
De-riveting the guards is fairly straightforward,... re-riveting them is not nearly so easy. Just so you know.
needaz1100r
#5 PostAuthor: needaz1100r » Wed Oct 15, 2014 7:54 pm
If I could borrow it Al, I can start on the bracket.
I will be seeing you shortly anyway.
Mark.
#6 PostAuthor: Al » Wed Oct 15, 2014 9:52 pm
No problem Mark.
If;... as you say the blade is the same as the J, i would be looking to cut the side plates off a J type one and replace with solid plates of the correct profile.
Much much easier than messing about with rivets and sets.
Was looking at this.
Its similar in shape / design but probably too wee.
http://www.ebay.co.uk/itm/KAWASAKI-Z250 ... 461cc51b7d
needaz1100r
#7 PostAuthor: needaz1100r » Wed Oct 15, 2014 10:05 pm
That's a fair point Al, easy to weld the new side plates to the old brace.
I've got a couple of 1100R mudguards so I can do a bit of measuring and comparing.
Mark.
needaz1100r
#8 PostAuthor: needaz1100r » Fri Oct 17, 2014 4:19 pm
needaz1100r wrote:Aesthetic condition not important, but would like a straight one.
I do want to pay for it, I should add...
Mark.
Users browsing this forum: No registered users and 4 guests
