hi all
just wondering if anyone has had a bad dyna coil from new,just fitted
new dyna electronic ignition and coils,but only getting spark on 2/3 not on 1/4,changed wires round to check modules on electronic ignition all ok.
changed coils over now sparking 1/4 and not 2/3,have put insulating tape round spacer near wire inputs,getting power to coils no spark,so would you say bad coil.
royboy
dyna coils
- Mark Tiller
Yes, as MarkT says..
The primary windings should read 3 to 4 ohms across them, whereas, the secondary windings should read 13 to 14 kohms assuming they are the "green " variety.
Also, check that the secondary coil caps have good connectivity.
I found by pointing the coil spouts towards the top front, I had to use longer plug leads. I purchased some right angle adaptors to save some length of lead.
It does sound as so you have a defective coil, which Dyna will/ should replace.
