Midz meet Sept 28
Vince2
Midz meet Sept 28
#1 PostAuthor: Vince2 » Sat Sep 27, 2014 4:17 pm
I presume this meet it still on? I've seen nothing about it but hopefully a few will be there.
Just to say, those arriving from Hinckley direction on A5 won't be able to turn right onto A444/Redgate so you'll have to ride past - probably for about a mile till you get to first roundabout near Atherstone. Go all the way round and come back to Redgate that way. You can turn left onto A444/Redgate that way.
Similar if you're comming up A444 from Nuneaton to A5, you'll have to go to Atherstone roundabout before comming back.
That is unless you find somewhere before the Atherstone roundabout where you can do a u turn SAFELEY.
See you tomorrow.
freddyz1r
#2 PostAuthor: freddyz1r » Sat Sep 27, 2014 4:44 pm
Look at the shout above :wink: :D
“It's not me who can't keep a secret. It's the people I tell that can't.â€￾
freddyz1r
PUM 329
Vince2
#3 PostAuthor: Vince2 » Sat Sep 27, 2014 5:01 pm
Durrrrrrr"......." :roll:
I've had a hard week! :oops:
MCZ900
#4 PostAuthor: MCZ900 » Sat Sep 27, 2014 7:20 pm
If it's not persisting down I will nip down to see everyone in the mk1
1973 Z1 and 1976 Z900
Muckmagnet
#5 PostAuthor: Muckmagnet » Sat Sep 27, 2014 7:35 pm
Hello yes the Midz meet is the sunday 28th sept . Steve put a shout on for me as im having to use my phone as lap top has given up on me . Weather looks ok so hopefully be on the bikes . Ted visiting again so he'll be with us too. See every one tomorrow xxx
Karen & Steve
Ridden not HIDDEN !!!!
Vince2
#6 PostAuthor: Vince2 » Mon Sep 29, 2014 1:42 pm
Thanks guys and gals. A great way to spend a few hours on a warm Sunday afternoon - riding each other's bikes. Only trouble is I now realise how bad mine is! :cry:
Checked what fork oil I use. Rockoil SVI 10
Think Paul said use 15 not 10. Any other thoughts?
Could the 10 oil be causing the constant 'pogoing' ( like fork chatter ). Also when I hit a hole or sudden ridge, there's a mechanical sounding 'knock' that comes From that area. Maybe forks not damping?
Paul, your zed's great fun but my license wouldn't last. :D
Steve, I promise I'll sort mine and you can try it again. :wink:
A1John
#7 PostAuthor: A1John » Tue Sep 30, 2014 1:11 pm
All early z1s have the "Fork Knock" the dampers were changed later in the run.
Vince2
#8 PostAuthor: Vince2 » Tue Sep 30, 2014 6:44 pm
Thanks for that knowledge John. Saves me trying to fix a fault that is built in!
Do need to sort out the damping though. I'll try the 15 grade fork oil and see what difference it makes.
#9 PostAuthor: ADRIAN H » Tue Sep 30, 2014 6:52 pm
Vince2 wrote:Thanks for that knowledge John. Saves me trying to fix a fault that is built in!
Could fit some of these.
https://www.z-power.co.uk/merchantmanag ... ts_id=1721
andyb1962
#10 PostAuthor: andyb1962 » Tue Sep 30, 2014 7:44 pm
Yep progressive fork springs and new oil should sort it :wink:
Andy :wink:
Vince2
#11 PostAuthor: Vince2 » Tue Sep 30, 2014 8:14 pm
Manual says 49.5cms standard. Just measured mine at 50.5, Z power's are 52.5cms so quite a difference.
Think I'll give them a go ( with 15 grade oil)
Cheers guys. :wink:
