hello, I'm looking for a set of salvageable hubs (drum brake). I have the rear brake plate.
Also main stand - mine has the kicker sawn off.
Also a z1 swing arm.
z1 hubs + stand + swing arm wanted
malmojoe
yes, the front hubs are the same.malmojoe wrote:A1John wrote:The hub on an H2 is different, the cush drive rubber locating peg is in the middle on an H2 and offset on a Z1RAYZ1 wrote:malmojoe wrote:anything? Are Z650 fron hubs the same?
h2 is the same as z1 rear hub
worth noting down. Thanks.
The front hubs are the same though aren't they?
I had problems with a hub, but the physical size was the same, so I bought the rubbers for that hub with the lug in the centre and all was OK.
http://z1ownersclub.co.uk/forum/viewtop ... hlight=hub
LE to JOG on a z900
P.U.M.
P.U.M.
Users browsing this forum: No registered users and 4 guests
