z1 hubs + stand + swing arm wanted
malmojoe
#1 PostAuthor: malmojoe » Mon Sep 22, 2014 8:24 pm
hello, I'm looking for a set of salvageable hubs (drum brake). I have the rear brake plate.
Also main stand - mine has the kicker sawn off.
Also a z1 swing arm.
malmojoe
#2 PostAuthor: malmojoe » Thu Sep 25, 2014 3:57 pm
anything? Are Z650 fron hubs the same?
A1John
#3 PostAuthor: A1John » Thu Sep 25, 2014 9:11 pm
malmojoe
#4 PostAuthor: malmojoe » Fri Sep 26, 2014 9:32 am
:beer
RAYZ1
#5 PostAuthor: RAYZ1 » Fri Sep 26, 2014 10:19 am
malmojoe wrote:anything? Are Z650 fron hubs the same?
h2 is the same as z1 rear hub
A1John
#6 PostAuthor: A1John » Fri Sep 26, 2014 10:39 am
The hub on an H2 is different, the cush drive rubber locating peg is in the middle on an H2 and offset on a Z1
malmojoe
#7 PostAuthor: malmojoe » Fri Sep 26, 2014 11:05 am
worth noting down. Thanks.
The front hubs are the same though aren't they?
A1John
#8 PostAuthor: A1John » Fri Sep 26, 2014 11:07 am
yes, the front hubs are the same.
Jumbo
#9 PostAuthor: Jumbo » Fri Sep 26, 2014 7:44 pm
I had problems with a hub, but the physical size was the same, so I bought the rubbers for that hub with the lug in the centre and all was OK.
http://z1ownersclub.co.uk/forum/viewtop ... hlight=hub
LE to JOG on a z900
P.U.M.
Z1parR
#10 PostAuthor: Z1parR » Sat Sep 27, 2014 12:30 pm
I have a six bolt hub Glyn .
0172 . Geoff Parr
malmojoe
#11 PostAuthor: malmojoe » Sat Sep 27, 2014 12:59 pm
Geoff, sent you a PM.....I think.
Users browsing this forum: No registered users and 5 guests
