Z1B fully restored, new pattern shocks (not brilliant I know), new taper head bearings (correctly adjusted), new swing arm bearings with pivot correctly torqued, frame is straight (it was bent @ headstock but had it straightened on jig 7 yrs ago - Seastar Superbikes in Norwich if anyone is interested).
The issue is stability, the bike tracks every rut/imperfection in the road and when crossing white lines/cats eyes, the back end shimmies/wobbles and generally feels loose. Over 100mph (on private roads of course!) and higher speed corners a weave sets up, this is affected by clothing, in leathers its better, in fabric jacket worse
Tyres are Continental ATTACKs (not latest version) with good tread and profile, pressures 28 front, 32 back, I use Kawasaki owners manual figures but should they be different based on tyre manufacturer as most modern bike tyres run much higher pressures?
John
I suspect its the tyres, the bikes were alledgedly fitted new with ribbed front tyres for straight line stability but with modern tyres this shouldn't be an issue.
Anyone have any suggestions / recommendations for tyres (from experience).
