Z1300 A3 (1981) IC IGNITER WANTED.
AERIAL0
With just having restored my Z1300 and had bike running all ok. For some reason have no spark and all points to IC unit.
Under the impresion that rare as hens teeth to get hold of.
Any body got one tucked away at the back of the shed?
AERIAL0
Thank you for the link. But without going for the cost to download info as checked all voltage and resistence to manual? Able to change transisters for £4 a throw wether that will sort the problem is the unknown. Have spent over 12 hours trying to sort.Gus wrote:This may be of some use to you.
http://www.carmoelectronics.co.uk/index ... _1830_2170
Gus
They are out there, but you have to look,and once found.. Be quick..sorry this one's sold..
http://www.ebay.co.uk/itm/New-NOS-Kawas ... 0728693501
And found this one...
http://www.ebay.es/itm/Kawasaki-KZ1300- ... 2a3e01cfaf
Re: Z1300 A3 (1981) IC IGNITER WANTED.
AERIAL0 wrote:With just having restored my Z1300 and had bike running all ok. For some reason have no spark and all points to IC unit.
I have a type 21119-1020 fusi electric
No idea what model its off ???
Can someone let me know
It came in a box of mixed kawasaki second hand bits.
21119-1020 SS 21119-1040 SS 21119-1429
Fits these-
Z/KZ 550 80 81
Z/KZ650 81 CSR
Z/KZ750 80 81 82 4 cyl
KZ1000G1 80 Z1 CLASSIC
Fits these-
Z/KZ 550 80 81
Z/KZ650 81 CSR
http://www.ebay.com/itm/CENTRALINA-KAWA ... 1297772528
AERIAL0
With a look at your photo and plugs. Its not for a Z1300. Sorry not able to narrow down to model. Hope another member can help you out.andy c wrote:AERIAL0 wrote:With just having restored my Z1300 and had bike running all ok. For some reason have no spark and all points to IC unit.
AERIAL0
Top member for info and thank you. But at around £260 for a unit shall go for plan F which is feck knows. next rought is to replace transisters at £4.00 apiece.Zed man wrote:They are out there, but you have to look,and once found.. Be quick..sorry this one's sold..
Please keep on passing on info as appreciate all input.
AERIALO, sorry but it's not looking too good, but keep trying.
http://www.kz1300.com/index.php/forum/e ... mitstart=0
Interesting read, 81 model is unique, but CARMO ELECTRONICS name came up in this discussion.
Good luck.
Good luck.
RGH wrote:I have a type 21119-1020 fusi electric
Fits these-
Z/KZ 550 80 81
Z/KZ650 81 CSR
Thanks , Now I can move it on to someone who needs it.
AERIAL0
Many thanks for responce re ic unit and all info. At least they are still out there. Unable to understand, one week working the next nothing? Spent over 12 hours checking all out and had enough. Could even be the pick up coils? Do not have the Kwack meter to test as my meter gives wrong readings. Never mind. One day will be sorted and in the mean time shall move on to my next project to restore.
AERIAL0 wrote:Thank you for info. Used in the past for spares. A good guy to deal with. Have spent a lot of wonga on the Z1300, and at the moment no biker fund left to get unit replaced. How many Z1300 owners on the forum? Still no joy re trying to down load photo's.
I hope your quest is successful.
Other Z1300 owners that I know of on the site are Myself , Ralph (VDUK),
Tonto (Tim) I would say that there are others out there.
Gavin
