I think i've got some (square hole) fork tops which are not rusty off a set of Z1R forks.
PM me and i'll bung them in post to you.
fork oil for z1000a1
evans wrote:Also do you need a special tool to compress the fork springs when try to reassemble ?
No chris. If I remember right just a bit of brute force and ignorance ( I have ample of both ).
It can be a little fiddly trying to push the spring down, with the plug (trying to get the first thread). You need to have the forks secured/still, so you have both hands available.
hope that helps, cheers freddy
