fork oil for z1000a1
what weighting fork oil should I use for 1977 z1000A1 ?
Chris
Chris
forks seals/forks plugs with recess
Thanks everyone.
There appears to be an additional plug under the actual top cap on each upper fork, with a recessed square locator to take a 1/4 inch extension bar, which is not mentioned in either the Clymer or the Haynes manuals. But how do you get that out ?? The upper forks are none standard as the take a air assisted mechanism for pumping up the forks and the top caps have holes in them which has allowed water in to the top of these plugs with the square recess, so are very rusted up. I clearly need to get these out in order to be able to fill with new fork oil.
Any input much appreciated.
Chris
Chris
freddyz1r wrote:Z1parR wrote:Yes
haven't you ever heard of 'sugar coating'![]()
(Ps if a lady ever says, "does my bum look big in this ?"
"No, you're arse always looks huge!"
Is not the correct response
"OMG!! that would look big in field full of Hippos," is also not a good response. My sister is still not talking to me
1976 KZ900
1976 KZ900
Re: forks seals/forks plugs with recess
evans wrote:Thanks everyone.
Hi chris, I've not seen the 1/4" plugs
1/2" ratchet end is what I've used
if it's the same as I've done you simply undo the plugs with the ratchet, they are essentially a 'bolt' (threaded).
Hope that helps, cheers freddy
