Z1000R-2
RUDDY
#16 PostAuthor: RUDDY » Tue Aug 12, 2014 8:55 pm
weaver wrote:the tensioner part that is jubileed is under pressure from a spring inside isnt it? thread of the cap is probably suspect and if it popped off with the engine running it would have been disastrous.
Yeah, those were my thoughts, a quick inspection I couldn't see any defect, spring etc internally looked fine, it will certainly get a thorough inspection if re-used.
85 Z1100R-1
Is Vic There
#17 PostAuthor: Is Vic There » Wed Aug 13, 2014 12:04 am
RUDDY wrote:
Is Vic There wrote:Nice work, did you manage to get the bolts replated drab green?
Not yet, will probably be a few weeks time as it's a 3 hour drive each way to drop them off, probably gonna go black on most of them as that's what they should be, I've been told that as the chemical black fades it can give an appearance of very dark green whereas the drab green is very green.
That's good information to know, looking forward to you showing us your nuts :shock:
RUDDY
#18 PostAuthor: RUDDY » Wed Aug 20, 2014 5:27 pm
Well, with the engine stripped it's been a week or so spent cleaning.
The barrels were degreased and I gently aqua blasted them, this morning I took them and the head to the local machine shop, unfortunately it's a one man band operation and he is into his classic bikes, so he's closed and at the IOM until next week .. :x
The crankcase has took some cleaning, every nook and every crevice, then it's been masked, acid etched and painted satin black, photos make it look more glossy than it is.
I've also made a start on other parts, blasting, painting or powder coating
Still not got to the platers :x
85 Z1100R-1
RUDDY
#19 PostAuthor: RUDDY » Wed Aug 20, 2014 5:29 pm
Should add the breather on top of the crankcase is getting done separate hence still showing primer.
Paul
85 Z1100R-1
Is Vic There
#20 PostAuthor: Is Vic There » Wed Aug 20, 2014 7:48 pm
Very nice, most people don't realise that the sump was originally silver.
Its getting there, keep posting the pictures.
RUDDY
#21 PostAuthor: RUDDY » Wed Aug 27, 2014 4:35 pm
So I've had all my engine cases gently blasted followed by Aqua blasting, then acid etch primed and baked satin black paint.
Really pleased with the finish, very factory, not as thick or glossy as powder coating can be.
Now the bolts, I had stock of satin finish stainless steel but also bought some black anodised stainless ones.......now I don't know which I prefer :(
85 Z1100R-1
Exhaust Craft
#22 PostAuthor: Exhaust Craft » Wed Aug 27, 2014 5:55 pm
Very nice
#23 PostAuthor: Ginger Bear » Wed Aug 27, 2014 6:46 pm
Gotta be black on the bolts........
...... Could you tell us where you get 'em from :?
# 104
RUDDY
#24 PostAuthor: RUDDY » Wed Aug 27, 2014 7:02 pm
Ginger Bear wrote:Gotta be black on the bolts........
Yeah, I'm deffo going black on all the fasteners.
There's a guy on EBay sells them in packs of 10 with black washers, use the options to select length and pack size.
Not sure they are annodised tbh, may just be chemically blackened but the ones I received today are very nice, just ordered a big batch in various lengths.
Cheers, Paul
EBay link, no connection to me what so ever
http://pages.ebay.com/link/?nav=item.vi ... 1307008875
85 Z1100R-1
Is Vic There
#25 PostAuthor: Is Vic There » Thu Aug 28, 2014 9:00 am
Good choice, mine have something similar fitted at the moment, what was fitted from the factory?
RUDDY
#26 PostAuthor: RUDDY » Thu Aug 28, 2014 10:24 am
Is Vic There wrote:Good choice, mine have something similar fitted at the moment, what was fitted from the factory?
They came with chemically blackened cap heads originally.
Had my barrels down to the machine shop yesterday , got them measured up, still on factory size with zero wear, they will get glaze busted and new std size rings fitted.
85 Z1100R-1
Is Vic There
#27 PostAuthor: Is Vic There » Thu Aug 28, 2014 10:30 am
That's a bonus then!
RUDDY
#28 PostAuthor: RUDDY » Thu Aug 28, 2014 1:32 pm
Well my new lift arrived today, it had great reviews so I got one off Amazon, only £82 delivered
And this afternoon I picked my barrels up, looking very good after glaze busting, £20 well spent, now to clean them a bit more before painting them.
85 Z1100R-1
weaver
#29 PostAuthor: weaver » Thu Aug 28, 2014 2:47 pm
I used one of those stands when I did my rebuild,I drilled it tho and bolted a piece of mdf to the top to give a more stable mounting surface
Is Vic There
#30 PostAuthor: Is Vic There » Thu Aug 28, 2014 8:02 pm
weaver wrote:I used one of those stands when I did my rebuild,I drilled it tho and bolted a piece of mdf to the top to give a more stable mounting surface
And makes a very large tray to put your spanners :lol:
Users browsing this forum: Google [Bot] and 7 guests
