Hi,
Been hearing a noise from under the cam cover of my Z900-A4 getting progressively worse. It appears to be coming from the central tunnel...on startup it idles ok, but when 2000 rpm is reached the noise starts...almost a vibration...taking it beyond 2000 rpm and the noise dissappeares but not running right.
Took the rear tensioner apart yesterday and all fine. Took the cam cover off and inspected the top idler assembly. The gear had a lot of movement (in all planes)...is this gear normally free floating (never had a good look at one of these closely before) or is this a sign that the idler assembly is worn...certainly seems as this could be the cause of the noise and the 2000 rpm mark could be it's sweet spot when all the resonance / noise starts.
Cheers.
Z900-A4 Cam Chain Top Idler.
- Paul Whitehouse
If it's too loud....too bad.
- Paul Whitehouse
- Paul Whitehouse
The best and cheapest is a Liska racing item at $84 (£50) as opposed to OEM from Zpower at £180.
The liska item is also re-buildable.
Even with shipping from the states you will save a massive amount and get a superior item.
You will have to email Liska with your order as their site is not set up for UK shipping but otherwise there should be no problem.
They also stock the four mounting rubbers and anything else that may be needed.
http://www.liskas.com/servlet/the-Cam-C ... Categories
- Paul Whitehouse
