Mine is cured 99%. New plugs, even though the "old" ones were new! Manually set slide heights. Adjusted air screws.
I noticed that plugs 3 and 4 looked weaker than plugs 1 and 2, perhaps that would be the cause? Perhaps some fuel starvation? The only common thing to 3 and 4 is the fuel tap and supply so I cleaned the fuel tap filter and checked flow was ok.
Took it for a 60 mile run, and it pulled like a train
will look at the colour of the new plugs tomorrow.
Next I'll do a vac check on carbs and see what that's like.
It has 17.5 jets, should they be 20 on a late 74 Z1A? Would 20 be better in any case with STD pipes?
It's now NOT going on ebay..........
If at first you don't succeed, try and try again. Then quit. There's no point in being a damn fool about it.
W C Fields
