Strange Noise from engine
z1000puddin
#1 PostAuthor: z1000puddin » Fri Jul 25, 2014 9:05 pm
Guys,
Looking for some help on my zed 1075.
With the engine cold ( not run for two days)
If I switch on the ignition key & without starting the engine, switch the key off.
I get a strange "Phhluff" from the engine for a split second.
(sounds like it comes the combustion chamber)
If I switch the key on again, even after a few minutes- The strange noise does not happen :?: :?: :?:
The bike starts, runs & goes well with no other weird symptoms.
Stu
Zed til Dead
Mark Tiller
#2 PostAuthor: Mark Tiller » Fri Jul 25, 2014 9:13 pm
Mine does the same
#3 PostAuthor: zed1015 » Fri Jul 25, 2014 9:14 pm
You have Dyna 's' ignition fitted ??
If yes then this is normal and it's just the spark igniting fuel residue in the cylinder.
All my zeds with Dyna's do this .
GIMPieZ650
#4 PostAuthor: GIMPieZ650 » Fri Jul 25, 2014 9:53 pm
As said, common dyna-s characteristic, nothing to worry about. sometimes you get a nice pop and a little flame if its hot
z1000puddin
#5 PostAuthor: z1000puddin » Fri Jul 25, 2014 9:58 pm
Aha,
Yes Dyna S fitted.
Thanks guys
Zed til Dead
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
