Z1r Float Heights
EGGPIEROE
Z1r Float Heights
#1 PostAuthor: EGGPIEROE » Mon Nov 19, 2007 6:57 pm
hi every one can somebody help me please ? can any one tell me the float heights for a 1980 z1r us import, and do you measure them upside down or the way when they are are on the bike
Thanx Alan :)
#2 PostAuthor: Pigford » Mon Nov 19, 2007 7:32 pm
Whatever the float height:
Remove bowls.
Invert carbs (thats upside-down to me & you :wink: )
Take weight off floats until they are only just touching needle valve (by tang)
Now measure from underside of carb body (metal casing where float bowl mates with body) to top of float (as they sit with carbs inverted)
You now have the float height. I think its around 20mm :?:
Do a search as this has been discussed before :wink:
EGGPIEROE
#3 PostAuthor: EGGPIEROE » Tue Nov 20, 2007 7:20 am
Thanx for that i will give it a go
Thanx Alan :)
zedtwo
#4 PostAuthor: zedtwo » Tue Nov 20, 2007 1:44 pm
I think it is 24mm.
#5 PostAuthor: chrisu » Tue Nov 20, 2007 2:51 pm
my book says 26mm for 1979/1980. I assume you have the Mk2 engine ?
#6 PostAuthor: chrisu » Tue Nov 20, 2007 3:08 pm
not sure if these 2 images will help. one shows how to measure float height (sorry about the crappy image). the other how to check fuel levels. this shows the std kawasaki tool but i made something up to simulate it.
Chris
