Leaking from carb overflow only on number 2
Hasbeen
#16 PostAuthor: Hasbeen » Mon Jun 23, 2014 8:26 pm
z1bman wrote:http://www.ebay.co.uk/itm/Brass-Tubes-2mm-7mm-300mm-long-0-45mm-wall-/360513204144?pt=UK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET&var=630063683206&hash=item53f042efb0
just twist the brass tube with some pliers & it should come out
I am a bit loath to do that as it is 2 different diameters. How would it be secured in the aluminium body?
#17 PostAuthor: PAULJAC47 » Mon Jun 23, 2014 8:29 pm
Real easy to solder Nick just need some resin core and a small blow torch.where are you located? would sort it for you if near to me..
#18 PostAuthor: z1bman » Mon Jun 23, 2014 8:37 pm
what is two different diameters?? the brass tube is just pressed in
Hasbeen
#19 PostAuthor: Hasbeen » Mon Jun 23, 2014 8:50 pm
Paul, I am in Yorkshire, gonna take it to work to solder tomorrow as my soldering gear at home is a little "industrial".
The tube is two different diameters, within the bowl it is a 1mm smaller than the bit outside the bowl with the "bulb" for the overflow pipe on. it must be stepped.
Nick
#20 PostAuthor: z1bman » Mon Jun 23, 2014 8:56 pm
[quote="Hasbeen"]Paul, I am in Yorkshire, gonna take it to work to solder tomorrow as my soldering gear at home is a little "industrial".
Nick[/quote
the brass tube inside the bowl is not attached to the one on the outside they are two separate tubes & are pressed into the bowl
Hasbeen
#21 PostAuthor: Hasbeen » Mon Jun 23, 2014 10:00 pm
Ah, that would explain it. Thanks, I will order some tube and give it a try if the soldering doesn't work.
Thanks for all the help and advice guys it really is appreciated.
Nick
