main bearing cap
kwaka
main bearing cap
#1 PostAuthor: kwaka » Mon Nov 19, 2007 10:22 am
Hi All
I'm in the process of reassembling the old girl and was wondering whether it would be better or not to put a little threadlock on the main crank bearing cap bolts? The manual says nothing about it so i assume it doesn't need it, however there are no spring washers or any other means of locking them in and wonder whether there is a possibility of them vibrating loose. Has this ever happened to someone?
DogsbolloxofZ1B
#2 PostAuthor: DogsbolloxofZ1B » Mon Nov 19, 2007 2:46 pm
Shouldn't be necessary as the circulatory forces are 90deg to the bolt orientation so no effect on them. I've never found any loose ones in the 30yrs I've been rebuilding them.
Mike.
